[WANTED] 1966 Barracuda Instrument Cluster
GhostFish
Illinois
I am in need or a working dash instrument cluster for a 1966 Barracuda. Probably a far off shot but I figured I'd give it a shot before going custom and aftermarket gauges. Thanks ahead of time!
I'm sure I have one but am in the process of moving to SC. Standard or Formula S? They are one of the best factory dashes out there, Is there something wrong with yours?
Stock non F-S and the previous owner trashed this setup, broke pins and cracked the circuit board. Only one of the gauges worked and that was the speedo. He also managed to mangle the pot iron backing on it. I think he was trying to install aftermarket gauges.
Hello,
I just listed my '66 Barracuda for parts or restore.
I have another '66 that will be cut to make a race car.
Not sure if it has what you need. If you still need dash parts, let me know.
Gasser Dave
Bump. Missed out on a cluster due to life things. Still needing a dash/cluster. Thanks FABO!
