66 wolfcuda
Member
I have a 66 Cuda that was restore 10 years ago then set under a carport waiting on a shop to build motor, shop closed and lost motor was 318 3 speed in the floor. Complete dual exhaust with factory manifolds still in car, complete bellhousing and clutch assembly is there. frt brakes were changed to large bolt pattern with new calipers, rotors and correct cadium plated power booster, new interior but carpet shows some color fade from sitting (needs dieing under back glass, rechromed grille and new emblems, new quarter mldgs, 8 3/4 housing with large bolt pattern axles and 3:55 posi installed but backing plates have not been hooked up. I bought a automatic console and shifter to change over, i bought a 360 short block 30 over with 272 Crane Cam and double chain with adjustable crank gear 2 degrees,4 degrees, 6 degrees, a set of 360 heads with daul valve spring, a torker intake. Everything goes for $4,500
Sedley, Virginia PM me for phone number or e-mail:cheers:
