1966 Dart Vent Window?
coalman
Texas
I need some information on the Vent Window Installation. What is the correct hardware that goes in front of the door that installs the vent window frame? Page 621 F-62 of the shop manual, showing attaching screws. Is it two cap bolts and two rectangular shaped spacers? Thanks a bunch!
mine were socket headed cap screws with the metal plate in the door to help stiffen the thin door metal. (mine is a convertible so it might be different on a hardtop
I think they are the same. I missing all of the plates, and one cap screw. I was going to adjust the vent wing inboard and found the missing parts, the cap screw was sitting on nothing. Thanks for reply..
I ahve a door that I'm going to use on the wifes dart I can take it apart and see what it looks like and post pic's if you need em.
Thanks a lot, if you can just send a picture of what you have circled would be great, I need to see what sits between the bolt and door. Thanks a bunch
ok will do.
Dropped a screw so you will need 2
the larger bolts go here.
2 3/4 inch tall
holes 5/8th wide
2" apart
that fits in the pocket under the rubber on thia door
hope this helps
Thanks, I didn't even get a notice that you sent these pictures. They are different, I might take a run out to a bone yard that has a couple of Darts and Barracudas about 40 miles from me. Thanks for all the pictures and help!
