moparman9
I'm selling my 66 Coronet 440 sedan. 273v8/904 torqueflite/8-3/4 rear end. The car is located near Greenville, SC.The car is in running condition and the body is solid with very little rust. There are some small pinholes in the lower door corners and in the trunk floor, and the inner fender under the battery tray is rusted. The radiator is not original. The dash pad is intact and the instrument panel and dash have not been cut. The original radio is still in place. I have a clear title for the car. The car will run, drive and stop in the yard, but I would advise towing it home due to the condition of the tires and the fact that it still has the single master cylinder. I haven't done much to it since I acquired it due to not enough time and money. the car does have brand new rear brakes. It needs a battery and I believe the turn signal switch is bad. I am asking $1600. PM if interested. I can take pictures of any specific areas of the car you would like a better look at and email them to you.
