[FOR SALE] 1966 Plymouth Valiant Signet
BogartBrian
New Member
Dade City
Rating - 0%
0   0   0
1966 Plymouth Valiant Signet, $12,000
This is an original hard top, no post, 273 V8 signet car. It currently has a '72 340 in it built 17 years ago. It has maybe 1000 miles on it. The buckets and a center console are from a later model A body. I still have the original 273 engine and the original 60/40 front bench seat. They both go with the car. It has rust in the usual spots. Most can be seen in the pictures. The engine compartment wiring harness is brand new from Year One. The wiring under the dash has been repaired but still has issues (no dash lights). The dash wiring harness is also available from Year One. New 4 core aluminum radiator. Brand new tires. The master cylinder is new but the wheel cylinders need replacing. It runs good and sounds strong but the carb needs to replaced. Older restoration on upholstery but is in very good condition. The carpet was recently replaced. Clean Florida title, located in Dade City, FL 33525. The rust shown in the pics are from the right side. The left side is pretty much the exact same. 10 pic limit.
