SlotCarWon
No this isn't mine but I did look at it but I forgot my camera.
==> http://detroit.craigslist.org/cto/870632580.html
The car is located around Port Huron Michigan. The owner is not very knowledable about A-bodies - so your idea of good and his might be different so you might need to have him explain things in some detail. It is very inexpensive and with a little help would be a good beater. As you'd expect the quarter panels have very large patchs and the floors have large areas missing. Almost all of the exterior trim has been removed. The engine has been replaced with a 70s one (it still has an EGR valve) and now has a manual choke. I think the only thing left of the interior is the door panels, one sun visor and the dash; the steering wheel mounting is loose & sloppy. Note - the wheels have been painted black but they are mags and there's not too much tread left on the tires. Not a lot of money for a very different car that apparently runs.
