273valiant
Member
First off the car is in Mission, BC Canada
This probably limits the interest on here but I figured it would post it anyways
Here is the Craigslist add I made
1966 valiant v8 - cars & trucks - by owner
1966 valiant 4 door with factory 273. All original trim is there, nothing missing. Power steering, manual brakes.
-New
KYB Shocks
All new brake lines front to back
Dual master cylinder swap
Adjustable brake push rod
Ignition relay
Ignition coil
Condenser
Ball joints upper and lower
Spindles
Calipers
Disk brake swap to big bolt pattern with 1” wheel adapters in the rear. 7.25 rear end.
Lower control arm re enforcement
Upper control arm bushings
Greasable pivot shafts with poly bushings
Poly strut rod bushings
Champion Radiator big 2 core
Spark plug wires
Carburetor
Straight pipe with glass pack exhaust sounds great
Trunk rust fixed and bed lined
Tires and wheels brand new maybe 500kms on them
Gas tank
Gas sender
Gas tank grommet
All new bushings in front end
New tie rods, sleeves, idler arm, pivot arm
Belts
Trans shifter link seal, filter, fluid and mount
Diff fluid
Billet gas cap
stereo (in glove box) and speakers
Fuel pump
Fuel filter and soft lines
Oil and coolant
Coolant filter
Alternator wiring upgraded and whole harness inspected with an ammeter and bulkhead bypass done.
Brand new carpet
Full sound deadening deadmat
Fresh alignment
Brand new battery
Battery ground cable
Engine ground
Air filter
Heater hose
Vacuum lines
Brand new LED headlights (have originals)
New dual throttle return springs
A lot more, over 8k just in parts in the last year. Floors are good, heat works etc
The bad - Dent on drivers rear arch, some rust on drivers door corner and rain rail, steering box could be tightened or rebuilt, with the new gas tank sender the gauge doesn’t read quite right needs a calibration. Paint damaged under gas filler from leaky cap.
Drive to work as much as possible, fully insured right now. Turn key ready to go, super reliable. Have all the original parts still, rad and brakes ect
Can send the vin if interested.
with that said it’s up for $7500 Canadian right now, so like $6000 usd. Before I get blasted about it being high. It might be I have no clue, they are a lot less common in Canada. Open to offers. Looking to get into a c10 pickup project.
-New
KYB Shocks
Ignition relay
Ignition coil
Condenser
Spindles
Calipers
Spark plug wires
Carburetor
Gas tank
Gas sender
Gas tank grommet
Belts
Diff fluid
Billet gas cap
Fuel pump
Oil and coolant
Coolant filter
Brand new carpet
Fresh alignment
Brand new battery
Engine ground
Air filter
Heater hose
Vacuum lines
