1966 valiant..
ir3333
ontario,canada
can 67 -70 a body suspension components be used on a 66 valiant?
A- arms,torsion bars,rear axle,rear leaf springs etc?
tx guys..
tx guys..
My 66 has 68 b'cuda front brakes/arms and 69 dart axle and many other various assorted a body suspension pieces.
The 66 model shares the platform of the 1963-66 models. The steering gear is unique aside from the steering box itself. Shocks, and torsion bars can be used from a 67-76 model. Sway bars from other years might be made to work if you can make brackets for a custom mounting position.
Snate mentioned brakes....Yeah, you can fit newer brakes but you'll need upper control arms with larger ball joints because the popular 11 and 12" BIG bolt pattern front discs were based on B and E body spindle sizes.
The rear axle bolts in from 63-76. The pads on the axle for the leaf springs is the same for all years.
