[SOLD] 1967 Barracuda Formula S Notch
bigrobsRT
Houston, TX
$9,900 obo
1967 Plymouth Barracuda Formula S Notchback
Yellow with black bucket seats and console.
Originally a gold metallic car. (I didn't paint the car just cleaned up the engine bay) Has some rust under the paint in the cowl, quarters and some other small spots. Underside still has most of the factory undercoat.
I have the IBM card decoded but no fender tag.
All trim and badges present except front PLYMOUTH on nose.
Rebuilt 273 .060 over
Egge 10.5:1 pistons
Summit Double Roller timing chain, Summit Balancer, Summit .454 lift cam (K50052)
302 heads with new valve seals-hydraulic lifters and stamped rockers.
new melling oil pump, new water pump
rebuilt edelbrock carb
Weiand stealth intake
electronic ignition (orange box) and distributor
New Accel Super Stock coil
New Summit headers coated with VHT header paint
A904 transmission
8-3/4 axle - not sure of the gears
Front disc brake swap and aluminum master cylinder.
Painless wiring harness
new O'Reilly battery
new battery tray
New throttle cable
New upper control arm bushings
New upper and lower ball joints
New inner and outer tie rods
New pitman arm
New idler arm
New sway bar end links
New steering coupler
New front rotors and pads
rebuilt rear wheel cylinders
New U-joint
New rear brake lines
New Jegs 2.5" dual exhaust
New horn contact ring and turn signal switch
New carpet
New rear seat cover
New package tray
New wipers
New front cooper cobra tires
Any body issues? Trunk and under carriage pictures also. Thanks
It looks like it has rust around the back window, will need a cowl and quarters. Has one rust hole in the drip rail on the trunk but the trunk is solid. Front floors have patches in the foot well from some prior owner.
No reason. Just a question..
Your post didn't mention the title was clean.
I'm in California, DMV is a pain with salvage titles, especially out of state cars.
Thanks for the info
can you show rust area's? cowl quarters
