cuda67man
Dug out another interior gauge bezel someone asked about.. Here is one from a 1967 Barracuda with a/c. This is NOT brand new but very tastefully redone and had the wood grain (aftermarket which was $45) put on it. there is 1 very small piece of it that was cut short at the very tip where it meets the center one over the speedometer lens that was glued back which you can notice but doesn't take away from the looks at all. just thought I would mention it. There are no cracks or breaks on the exterior skeleton of the bezel and the radio area is still intact. The only spot where there was a small piece missing was the back side where the headlight switch goes thru the bezel. I put a small washer in the hole from the front where the chrome bezel tightens the switch and it is hidden from sight completely and it tightens the switch with NO problems. As you can see from the pictures you could never tell. This piece comes with a headlight switch and the flasher switch. Very nice daily driver bezel 210 plus ship.
