1967 barracuda locking gas cap insert
Slantsix64
Los Angeles
i have the original gas cap on my barracuda but with todays societys have it able to pop open easy is not a good idea. is there a small locking gas cap i can insert into the original gas cap>
There is a locking insert for Barracuda & Charger flip tops. It fits in the filler tube.
NOS ones can run as much as $500.00! Here's a link to a repro one for a lot less.
Mopar Parts | MP700140 | 1967-70 Mopar A/B-bodies - Locking Fuel Cap (Flip-top Style) with 2 Keys | Classic Industries
I've been using one for 4 yrs & have not had any problems
Some advice: DO NOT use the anti-siphon spring. It is a huge PITA. It interferes with the flow of modern gas pumps so that you can only trickle in fuel manually at the slowest setting -- you can't use the stops. Nothing like standing there bent over squeezing that handle for 20 minutes while your fingers go numb... My Barracuda FB had one of those in it and I eventually pulled the tank and replaced the filler neck just to get rid of the stupid thing.
