chickendeluxe
These fenders are not reproduced.
This listing is for a 1967 Plymouth Barracuda Right Front Fender Good Used.
This fender has some areas of note.
It has some rust present in the dogleg and in the leading edge (pictured)
There are also some small dents in places (see Pictures).
The outer dogleg will need repair as it has some rust but the inner brace is VERY nice. (See Photos)
There is work behind the leading edge but the leading lip is straight.
However this is a very hard to find and very nice original steel front fender.
This is a 1967 fender but if the marker hole is drilled it would be correct for a 1968.
This is a Chrysler Parts department replacement Fender
Part # is stamped inside.
Super Solid Passenger Fender with excellent framing.
I bought this fender in Florida since it was nicer than mine.
I had too much time into mine so I decided to sell this one.
$550 ofr
$550 ofr
