[SOLD] 1967 Barracuda reverse light housing
VOETOM
KC, MO area
I am not sure but I think this is a 1967 reverse light housing. It is pretty rough looking inside but not bad on the outside but it is missing all the good stuff inside.
Worth $10 to anyone?
Thanks!
64086 is my zip code and I bet to ship it costs $7.
I'm not totally positive Tom but I think those are 69's. The '67 and '68 had the backup lights built into the tail lights.
I know for sure it is a lower profile one but not sure where I got it; thank you for sharing more info LeAnna!
Tom
67 had the short reverse bezels in the lower valance. Early 69s used the remainder of the short reverse bezels chrysler had, then switched to long reverse light bezels for the remainder on the 69 model production run. 68 is the only year the backup lights were integral with the taillights.
What you have is a short bezel. This works for any 67 barracuda, however it is also correct for an early build date 69 barracuda.
Hope this helps
Matt
Nope
What you have is a short bezel. This works for any 67, or is slso correct for an early build date 69.
Hope this helps
Matt
Thank you Matt (and I suspect Leanna says thanks as well).
Your welcome.
I have 2 sets of short bezels. One for my 67, and one for my sons 69. His is a late build 69, but once they are mounted who cares as long as both are the same length.
You may want to clean it and look for an L or an R on the inside of the casting. May help you sell it easier if the prospective buyers know which side its supposed to fit.
