1967 Barracuda. what are largest front and rear tires i can use with my 15x7 sbp wheels? 4" backspace?
FASTEDDIE1960
iowa
Hi folks, trying to find out the largest tires i can use front and rear on my 1967 Barracuda. I have 15x7 SBP US Mag wheels, with a 4" backspace. Car has stock suspension with drum brakes. Thanks much
Front 15x8 205/65/15 8x25.4 Not sure of the B.S.
Rear 15x8 w/ 4.5" B.S. 255/65/15 10x28
225/60/15 is probably the biggest you can go up front, 255/60/15 out back. A 275/60/15 will fit most Barracuda’s in the back in stock form, but it’s pretty tight and that tire should be on a 15x8”. On some cars it could take some fender rolling, or a small spacer to get them off the springs depending on which rear axle you have, because the 7.25 and 8 3/4” rear axles are not the same width.
Thanks, it is an 8 3/4 rear end
