1967 BH Slant6 w/ rebuilt 904 and Gear Vendor OD
JBL1967
New Member
Apex, NC
I've decided to stop the rebuild of my 1967 Slant6 block (BH model with forged crank).
Block and head will have to be machined.
Crank has been machined 0.010 under by local speed shop (see receipt and package pics)
Original cam was reground based on Clifford recommendations, for use with their Weber 2-barrel
and long-runner intake (I don't have the carb nor the intake).
But all other parts are original, and would probably need replacing.
New AussieSpeed finned valve cover (unpolished)
904 trans rebuilt by '727 Specialists', and GearVendors O.D. installed.
New Coan Engineering torque converter (pro-street model w/ 1800 stall).
New Stef's trans pan w/ lube locker gasket (holds one quart more than stock).
New Melling oil pump (original pump gear has been pressed on for better reliability).
New oil pan dipstick.
I have the original oil pan, and a truck oil pan w/ new oil pickup.
Several Fel-Pro gaskets for oil pump, water pump, valve cover, oil pan.
I'd like to get $3500 (The GearVendor unit is $3100 by itself).
50-under on the crank... Don't often hear of a crank going more than 30-under
Yeah. I don't know where you would find bearings for it. I have an assortment of slant six bearings. .001, .002, .010, .012, .020, .030, .040, have never seen .050 but that doesn't mean they are not available on special order.
I didn't think they started the BH series yet til '68/69ish? Small or big crank pocket? In 50-sone years it's hard to say what someone else has cobbled together?
Thanks for the comments.
I had the crank done in 2022, and it was hidden behind some parts.
My old brain didn't help either......it's .010, and I added pic of receipt too.
I asked Doug Dutra to run the block code a few years ago, and I thought he said it was 1967....i added a pic of that too.
