illrad91
1967 dart inline 6 2 door hardtop original body interior and rear ended still in it. Stainless steel brake line- set cold case aluminum radiator- powermaster alternator-firm feel sway bar front-Ron francis wiring kitqa1 lower control qa1 crossmemberdenso small starterdr diff disck brake knucklespst front end poly bushing super inner tie rod ,adjusting sleeve ,idler arm assembly, cam bolt kit sethotchkis adjustable strut rodsmiloden car oil panelborgeson power steeringjigsaw power steering dr diff aluminum master cylinder and kitgts 4 linka body 8 3/4 reared 3.23 gears with 741 casing and have bigger casing also hemi denny hdk upper control arms71 front disk brake setup with extra calipersspeedway rear disk brake setup1981 or 82 not sure 360 small block la less than 10k on it with 727 torqueflightwith edlebrok 4bbl carbmsd billet distholley electric fuel pumpdougless tti long tube headersdriveshaft for the conversion to rearendmore but don't rememberthe front end has been put in with disk and the motor and trans as well along with the radiator.it is a complete and original car as is interior and exterior except for the steering column. There is no gaps between fendershave pink and registeration in for his year. Now put on non op. gts 4 link company was bought out by holley so idk about the warranty on the 4linkrust hole size of a golf ball under passenger dash in truck a bit of rust that needs to be removed 13k or best offer no rush to sell so please no low ball ive spent over 15k just in parts. Or willing to trade for a 4x4 sr5 Tacoma 1997-2000 or a Jeep v6 nothing under the Tj please thank you. Any questions message me it is located in sacramento
