big block scott
Active Member
This is a lovingly restored 1967 Dodge Dart GT . Metallic Silver body with a Black vinyl top over Dark Blue Metallic upholstery with carbon fiber accents on dash and console . Under the AAR , Six-Pack Hood is a freshly rebuilt 1968 - 383 HP with 10/10 steel crank and std. flat top pistons . The rebuilt 727 contains Kevlar clutches and bands , shift kit and a new convertor , which is all controlled by a pistol-grip slap stick shifter . The rebuilt Posi rear has 3.73 gears with 14" magnum 500's and BFG T/A radials . Power Front Disc brakes . A custom made dash holds a Six Gauge Instrument set and A/C controls . Also a six speaker , Blue tooth stereo so you may answer phone or listen to your playlist " Hands Free " . New Sanden compressor with Buchillion Performance mounts to hide it under the 120 amp , one wire , Alternator . A/C hoses routed under inner fender to conceal . MSD ignition control , MSD Blaster coil , Firecore billet distributor and H/D plug wires . Holley double pumper carb and Holley blue pump feed the Edelbrock performer intake . Aluminum 26" Radiator , High Torque Mini Starter , Tri-Y Headers with 2 1/2" dual H pipe exhaust and correct tips , Optima battery mounted in the carpeted trunk .
This beauty is located in Ocoee ,FL. on the west side of Orlando , near the Turnpike or 429 and Hwy 50 . Please PM to make an appointment to view . $32,500 OBO
Thanks , Scott
Thanks , Scott
