[FOR SALE] 1967 Dodge Dart GT 273 4bbl. factory buckets and console, rottiserie restoration.
MoparCrazy34
Small time Mopar Collector
Thorsby Alberta Canada
Rating - 0%
0   0   0
This little gem runs and drives as good as it looks, everything has been done properly pretty much factory spec other than a mild cam and 318 heads. Dual exhaust was not original nor are the 14" '71 Ralley rims. Radio/stereo also upgraded. $ 30,000.00 cdn./22,500.00 usd.
Any pictures of engine bay or underside ? Any power assist such as steering or brakes ? Drum or disc ? Is that a factory tach on the console ? Caught my eye and it looks nice but more information would help.
Thanks
Thanks
Yep, pics of under hood would be nice. I assume 7-1/4 rear end?
How difficult would it be to transport, title and register in the US? If the process isn't too crazy, I would definitely be interested....
Thanks, Bill
Thanks, Bill
Not difficult at all. A little bit of paperwork and of course a few dollars. I've only had experience importing from the US to Canada and from what I've heard it's simpler going the other way. Some other members here might chime in with their thoughts / experience. Might even be different from state to state ??
Thanks, I will check with our local DMV.
Couple of other questions....any paperwork, fender tag, certicard, vinyl roof or painted ?? How long have you owned it, did you restore or purchase in current condition.
V02 car I hope, would love to see the fender tag! I picked up a car myself in Winnipeg about 15 years ago and it was simple, probably not as much today but still shouldn't be an issue...
It's not the DMV that might have questions it would be the Customs and Boarder Protection Agency at the pertinent boarder crossing. As long as you have a signed title and bill of sale shouldn't be an issue. To be safe ask the agency directly.
Thanks
No Pic.s of underside just yet, Drums and no the tach is not factory.
A bit tough to read. What is under the first line a+b? How about the second line X7Y? and the PNT is it DE2?
Hi
I will take a better pic of tag when I am back to the garage I have it stored in, this will take a day or two as it my quonset is a 2 hour drive from here. Thanks for your interest, if there is anything else you would like a pic. of let me know. I will try and get some of the underside for you as well.
Bill
I have paper work coming , and will share with you when I get it, Roof is painted-original color of roof was baby blue. Mostly restored by professional restoration shop.
It seems that when sent by email, the fender tag is clear and expandable, I also have a summary list of work completed if you would like,send me your email through a PM, and I will get it off to you, if you are still interested...
Bill
Block casting no 2806030-273-1
Block build date 10.19.66
Car build date 12/1/66
Odometer Reading 34274
Winter 2018/2020
Teardown
Lower Rad Hose Fitting, water pump and Bypass hose wrong size 1970 Up version
Engine
Stock Bore
Normal Bearing Size
Pistons Good - Bearings Worn
Frost Plugs Rotted
Water Pump Rotted
Hose Sizes incorrect > Bypass hose and bottom rad Metal in Pan and Pick up tube - assume left from last rebuild
Camshaft Purple Shaft Mechanical P4529346
Lift .490/.490 Lash 28/32
Duration 276/276
Overlap 52
Center Line 112
Drag Mild Comp
Power Band 2600-6700
Head Casting
2843675
1967/69 273 and 318
Machine Shop Findings
Bore tapered at bottom .017
Crank low side of spec
Bore block to .040
Rod Bearings .001
Main Bearings STD
Commando Engine Kit - Pistons 10.5
Ordered kit from Falcon Engines
Assembly
New Cam Bearings
Block hot tanked
Bored .040
Crank Main Plastigauge - .0015 - .002
Rod Plastigauge - .0015 - .002
Compression Ring Gap - .022
Replaced Cam Bolt and Spacer Added Oil Slinger on Crank
Painted Block - Chrysler Red
All new Frost Plugs
New Water Pump
Bypass hose from 70 up
Replaced front cover to get a timing mark
Replaced Dipstick and Tube
Streetmaster 318 intake added
Edelbrock 500 Competitor Series Carb
Fabbed new kickdown linkage, fuel line, throttle and choke system
Piston to Valve Clearance - not measurable (lots) to head and to valve
Lower Rad Hose - Gates 20958 Dayco 70780 - shortened
Upper Rad Hose - Dayco 70975 - shortened
Bypass Hose - Dayco 70637
Fire Up
Oil Pressure 75 lbs
Clean Start - No issues
Antifreeze leak - water pump bolts, lower and upper hoses
Trans good - Clean, paint and service kit
Added Shift Kit
Replace shifter selector seal #8017
Clean and Paint Driveshaft
Rear Diff
Clean Up and Paint
Replaced Steel Brake Lines
Replaced Rubber Brake Line
Replaced Spring Bushings
Replaced Diff Vent
Paint all drums VHF cast paint
Clean brakes, adjust (recently new)
Body
Rust
front floors inside
Right Fender bubble under rocker trim
Left Fender bubble above rocker trim
Inner Fenders at Firewall
Left Inner Fender below battery box
Trunk hole by rear crossmember
Right Rear Quarter around fender lip
Left Quarter Behind Wheel
Both Trunk Extensions
Repair on Right side trunk floor badly done
Right Side Outer Wheelhouse Required
Left is fine
Steel
Quarter Skins Replaced
Trunk Drops Replaced
Trunk Floor Repaired
Rear Crossmember extension repaired
Right Outer Wheelhouse Replaced
Right Pass Rear Floor Repaired
Driver and Pass Front Floor Replaced
Repaired Back Drivers Inner Fender to Cowl
Repaired Back Pass Inner Fender to Cowl (small)
Repaired Rad Support Lower Left
Small Patch on Right Lower Fender
Lower Patch on Left Lower Fender
Clean Up Previous Patch Left Fender to Inner Fender
Redrill holes for Fender to Rad Support
Drill holes for Rocker Moulding
Drill holes for Peak Trim on Quarters
Paint
Roof Paint PW3 white
Inner Fenders and behind quarters POR15
Underside - Semi Gloss Tremclad Black Sprayed
Body Paint PBU True Blue Pearl
New Fuel Tank and Sender
New Fuel Lines
New Brake Lines
New Fuel Cap
New Headlight Bezels
New Taillight Assemblies
New Bumper Front
Rechromed Rear Bumper
Replaced Chrome on Hood, Windshield Reveal
Polished Drip Rail and Rear Window Reveal Mouldings
Front Suspension
Replace LCA Bushings and Pivot Pins
Replace UCA Bushings and Cambolts on Left Wheel (had
to be cut off)
Replace K Member - New style Idler Arm
Replace Idler Arm
Replace Tie Rod Ends
Replace Strut Rod Bushings (1 strut bent - press repaired)
Shocks Monroe 32022 Front 31131 Rear
Added Front and Rear Sway Bar
Alignment to Factory Specs
Steering Box Leaks
Replaced worm gear and pitman shaft seals
New Return Hose
Added missing o-ring on pressure hose
Replaced Steering Box to Remove Excessive Play
Cleaned and Repainted Wheels
Fit with BFG Radial TA Tires
Interior
Clean Door Panels and Repair
Paint trim and dash body colour
Recover rear seat
New Foams and recover buckets
New Carpet
New Console Carpet
Rebuilt Heater Box
New Armrests and Bases
New Door Pulls
New Window Cranks
Replaced Right vent Glass
Rebuilt Right vent pivot pin
Replaced Vent Window Pivots
Replaced Ashtray Chrome Door
Replaced Shifter Handle
Add Tach in Factory Console Position
Refaced Console Top Plate
First Oil Change
Aug 28, 2019 34770 5 litres camoil hp-3001 oil filter k&N
March 25 2015 36550
Shift Kit 10226
Trans pan gasket 4295875ac
Rad Descale
Billet thermostat Housing
July 17, 2023 39522
Oil and Filter Change - Baldwin Filter
5 Litres camoil
Thanks
Teardown
Engine
Stock Bore
Normal Bearing Size
Frost Plugs Rotted
Water Pump Rotted
Duration 276/276
Overlap 52
Center Line 112
Drag Mild Comp
Head Casting
2843675
1967/69 273 and 318
Bore block to .040
Rod Bearings .001
Main Bearings STD
Assembly
New Cam Bearings
Block hot tanked
Bored .040
All new Frost Plugs
New Water Pump
Added Shift Kit
Rear Diff
Clean Up and Paint
Replaced Diff Vent
Body
Rust
front floors inside
Left is fine
Steel
Paint
New Fuel Lines
New Brake Lines
New Fuel Cap
New Bumper Front
Front Suspension
to be cut off)
Replace Idler Arm
New Return Hose
Interior
Recover rear seat
New Carpet
New Console Carpet
Rebuilt Heater Box
New Door Pulls
New Window Cranks
Transmission
Shift Kit 10226
