ckdezert
Active Member
This car has had the entire running gear/Drive train either rebuilt or replaced with performance parts.
Motor:Completly new.Dyno run @422 HP.442 Torq:Built early 360. .030 over with Wisco pistons,Elderbrock RPM intake,Holly 770 Street Avenger carb.T&D 1:6 roller rockers,Roller lifters,Comp roller cam.Brodix B1 aluminum heads,Huge oil pan,Hooker comp headers,March performance serpentine belt set up.balanced rotating assembly.10:1 comp-runs great on pump gas.Built,broke in and jetting dialed in by IMM engine and dyno.
All elec by MSD.has new MSD control that the RMP limit can be adjusted with a turn of a screw driver.
Auto meter monster tac with shift lite,oil pres,and temp guges.
3core aluminum radiator with two spal electric fans.
Trans:727 auto,Built by Hughs performance.Street/ Strip,Manual/Auto valve body,Huge aluminum oil pan.B&M cooler.2500 RPM torq by TCS. Billet steel-this thing is built proof.
Strange eng rear driveshaft with 1350 ujoints.
4 wheel disc brakes,Front is rebuilt front end from newer dart that had disc brakes
Rear has SSBC disc brake kit.
8 3/4 rear end, Narrowed with cromolly axle shafts,sure grip posi,3:55 gear.Ajustable snubber.
Mini tubed rear,with mopar super stock rear springs.
3" X pipe exhaust painted flat black.2 Dyno max mufflers. Sound Wicked
New fuel tank,elect fuel pump,fuel lines,ect.
10"wide rear wheels with Mickey Thompson street ET radials.295-55-15 Street legal slicks.
7"wide front mickey Thompson 235-60-15
Optima red top battery in the trunk.
Frame connecters installed that tie into the rear spring perches for added strength.
New reproduction rear brake light assembleys.Recromed rear bumper.All the turn signals, brake lights,head lights all work.This is a turn key car.Cruises down the freeway no problem. Is a real head turner around town.Usally the only Dart at car shows.The body is rust free.we have put around 900 miles on the car.Was set up for street with a the intention to getting out to the track with it.So all this stuff is in as new cond.Paint is great from 10 feet away is the only real bummer with this car.
Possible part trade for small car like Toyota,Honda,or ?
$16,900 offer
Located in Indio,CA. (Palm Springs area)
No paypal, shipping, cashiers checks, or B.S. please
$16,900 offer
