[FOR SALE] 1967 Dodge Dart GT
jimmyjak
Member
little falls, mn
Rating - 0%
0   0   0
1967 Dodge Dart GT. All original Dart GT. 273 v8 with Air Conditioning that still has Freon pressure. Engine is running on a jug due to stinky gas tank. The engine does have a low compression in cylinder 1 causing a misfire. However the car drives and has good brakes. It will drive itself onto a trailer. The roof is main rust problem on the car. There is a soft spot as well in the drivers side floor and pin holes in the trunk pan. I am including a replacement trunk pan. The car has a title, certicard and build sheet. Asking $6500. Little Falls, MN
Can you please give more details on the roof? Is it rusted through?
What area(s) are bad?
Frame rails/ torsion bar mounts condition?
This is an original Texas car. Frame is solid and torsion bars are solid. Roof has a couple rust pinholes through in the front above windshield and also there is a rust hole below back window. I added pictures.
