avarageerod
This is my 1967 Barracuda. 440 with 727 and a 8 3/4 in the rear.
I'm not sure of the specs on the 440, it didn't matter to me. It runs very well and is strong. The transmission shifts good, but does leak from the dip stick tube if the car sits. The 8 3/4 rear is in good shape, no funny noises. Currently has 4:56 gears in a 742 case and a sure grip.
Car has rust, mostly in the rear. Both quarters have rust and the trunk. The underside of the car is in good shape as is the frame rails.
This car has alot of new parts, alot of which I'll probably forget to list. It has new...
The video is before I put the strips on.
[ame="http://www.youtube.com/watch?v=WTeR8sjrI70"]http://www.youtube.com/watch?v=WTeR8sjrI70[/ame]
- B&M ratchet shifter
- disc brakes on the front
- master cylinder
- radiator
- alternator
- hoses
- fuel pump
- header gaskets
- gas tank
- sending unit
- 195/70/14 tires on the front
- 275/50/15 on the rear
- sub frame connectors
