[FOR SALE] 1967 valiant 100 four door
barracudajohn
whitehall pa
Rating - 0%
0   0   0
I bought this car 14 years ago with the intention of using it for a parts car, I no longer need it. 225, automatic with factory air conditioning, also has a factory front sway bar and kelsey hayes front disc brakes. It was originally from Arizona, only rust hole that I see is a small hole in the passenger side floor. I believe that the mileage is correct. When I bought it, I went over the brakes and rebuilt the carburetor . Starts and runs, brake pedal low from sitting, probably has a leaking wheel cylinder, so brakes need to be gone over. Tires were new, 14 years ago, they should also be replaced if you intend to drive this. Photo will show an area on the driver's side quarter panel that was dent pulled and has bondo. Front seat needs recover and headliner came apart at the seams, so that needs to be replaced. When I bought it, I was given a signed title for it from the seller, DO YOUR HOMEWORK AND MAKE SURE THAT YOU WILL BE ABLE TO GET THIS TITLE TRANSFERRED TO YOUR NAME, if you want to license and register this vehicle. Asking 2800.00 or reasonable cash offer.
So technically it is still in the previous owners name as you never transferred into your name ? Do you have a bill of sale from that transaction ? I see at that time you had it notarized. Just trying to do my homework.
Thanks
