[FOR SALE] 1968-1969 Barracuda Rallye Cluster
tvu370
Active Member
Rating - 0%
0   0   0
Sold... One used cluster,bezel and heater controls removed from a parts car some time ago. $200.00 plus shipping costs. If your local your welcome to pick it up in person.Bucks County,Pa near Philadelphia
Any idea what was mounted in the hole down and left of the flasher switch mounting hole? Any cracks?
Are the pins on the circuit boards all there and tight?
The circuit board has all of the pins,bezel is free of cracks,no I do not know what was mounted in the hole.
That's a different hole. The trip setting is to the left of the speedometer, my 68 has that too. This bezel has an extra hole drilled by the flasher switch in the black part of the bezel. You can see it better on the pic from the back side. Maybe a clock adjuster cable?
