This timing cover is correct for small blocks 1968-1969 thou it will work for earlier models also. This cover has the timing marks cast into the cover and is on the passenger side. I cleaned and media blasted the cover inspect it for damage. Chase all the threads with a tap. Any hole that is not up to par I install a Heli-Coil insert. Includes the lower two water pump bolts. And is paint Chrysler Red. This is a hard to find timing cover. Mopar part number is 2946797 and is date coded 1969. $105.00 shipping included in the USA.
