[FOR SALE] 1968 340 short block
moparraceman
mansfield ohio
NEW NEEDS ASSEMBLED this way you see what your getting block been cleaned cam bearings are good, but also has new set to go with block i have a steel crank std-std that was in this block good shape , rods have new arp bolts resized ,new seal power [speed pro ]pistons look like oringal ones 10.5-1 , new rings,clevite rod and main bearings new std std, nice oil pan and hv pump and pick up. new brass freeze plugs, front timing cover,steel crank balancer .used very little water pump,distributor drive shaft and gear ,comp double roller timing chain set new fel pro blue head gaskets and fuel pump NO CAM buy what you want $2250. pick up a set of J heads would have a great motor cheap pick up mansfield ohio site wont let me up load pictures will try later
