[FOR SALE] 1968 340 SHORT BLOCK APART NEW
moparraceman
mansfield ohio
have for sale a 340 STD block 8-10-68[ could have also been used in 69 car ] cleaned ,has STD steel crank ,stock rods redone with arp bolts , stock 10.5-1 pistons .have new cam bearings,freeze plugs,rings ,rod and main bearings.also set of felpro blue head gaskets .used comp double roller timing chain gc also encluded front timing cover ,water pomp and fuel pump.NO OIL PAN OR PICK UP OR PUMP .does have steel crank balancer .$1800. also at extra cost like new set of J heads still in plastic from head man 2.02-1.6 valves new comp springs up to 600 lift ,10 regree locks and retainters $800. if interested pm me here threw conversation thanks
