[SOLD] 1968 340
QuintinMotorCompany
Georgia Vermont
Rating - 95.8%
23   1   0
1968 340 .. Very Complete including Aluminum Torker intake, thermoquad carb, M/T valve covers, and more!
Crank Drilled for 4 speed
Needs Rebuild!!
Nice starting point!
$1,500 OBO + crate or local pickup from 05454
Could you post the VIN? If it is a 68 it will be stamped on the rear top edge where it bolts to the trans. If it is a 68 casting date for a 69 car it will be stamped on a pad on side of the block just above where the oil pan bolts on. Thanks
I will check on that tomorrow.. Thanks!
find that vin number yet, please post. you may reunite some one with the motor out of their car.
Why don't you pull the heads so everyone can see what it looks like?
