[WANTED] 1968 Alternator
Albert19
Calgary
Rating - 0%
0   0   0
I'm looking for an alternator that is stamped with 2098850 and has a 1968 date code. It should have a single groove pulley for my needs. Send me a message if you have one for sale. Thanks for looking.
Dennis
Struck out. Hope morparparts can help you out.
What I have:
Alt #1
1. Pulley side 1/2 case - 2095191, no date code, the word "Lester"
2. Diode side 1/2 case - 2098835, 45 64, stamped on assembly date location
3. Same diode side 1/2 case - 2095192 between two fins to the left of the left side GRD marking
4. Same diode side 1/2 case - 6, the word "Lester" to the right of the left side GRD marking
5. Same diode side 1/2 case - a symbol that looks like an airplane (like a small v inside a large V)
Alt #2
1. Pulley side 1/2 case - no markings
2. Diode side 1/2 case - 2098835, 7 65, stamped on assembly date location
3. Same diode side 1/2 case - 2095192 left of the left side GRD marking
4. Same diode side 1/2 case - casting date wheel 65 in center, 2 dots in between 12:00 and 1:00 marks
5. Same diode side 1/2 case - KCP and DP/CD symbols
Pulley #1
2095430, S, 2-15/16" dia, excellent condition
Pulley #2
No part number, 2-11/16" dia, heavily pitted
I'm going to post a free add with the above info.
