dmb2468
Member
1968 Plymouth barracuda backhalved with ladder bar and single adjustable coilovers,8 & 3/4 rear with 5.13 Richmond gear, wildwood disc brakes on front, drum brakes on rear,stock dash with auto meter guages,grant gt steering wheel,weld wheels,31x13x15 M/T slicks,has all original glass and doors,weighs 2800 w/ sbm and glide.runs low 6.80's w/ 408. May sell t/k if interested.$7500 roller no motor or trans.Aluminum radiator, electric fan,tci trans cooler w/ braided lines,cheetah electric shifter,jaz fuel cell with Holley pump,,msd 6al and coil.
If interested T/k 360 stroked 410" probe forged pistons,eagle steel crank,RPM H beam rods,Hughes 7276as .629 lift cam with Hughes lightweight lifters and springs,ported x heads with fresh valve job,m1 intake,Holley 750,headman 1 7/8 to 3 1/2 coated headers,mopar valve covers,Moroso oil pan, and fluid damper,and csr anodized water pump.godley glide with brake, jw ultrabell and tci converter. 50 1/8 mile passes on engine 25 on trans.located in Ga. $7500 rolling $14000 t/k message for more pics or info.
