topless68
Active Member
Thank you for looking
68 Plymouth Barracuda Convertible, Clean original car + hundreds of parts
Up for sale is a very solid example of a 68 Barracuda convertible with the 318 auto, and Factory a/c. 92,526 BOX A miles! Blue, on blue with a white top (new top currently being installed). New blue carpet being installed.
The original 318 and 904 transmission operate well, and drive nicely. The 318 was recently removed, cleaned, and resealed, and upgraded with an Edelbrock Performer intake, and Edelbrock 4 bbl carburetor (still have original intake and 2bbl). During this, the engine compartment was cleaned, and re-sprayed in the original blue. No rust or damage repair was needed, it was a simple scuff and shoot... the firewall is original paint.
The undercarriage of the car is extremely clean, and solid. The front end was recently rebuilt, and received a disc brake conversion. The rear end is an 8-3/4" with a new center section of unknown gearing (might be on storage case where the unit came in... the original center carrier is stored in here). The rear also has new leaf springs.
The body of the car is in very nice shape, appearing to have only been repainted once. The paint would buff out and look very presentable as is, or would take minimal work to re-spray. There is no body damage at all, with only a little rust blistering in one rocker panel, and some behind the rear window, both simple repairs. The bucket seat interior has new front seat upholstery (driver's installed, passenger seat in process), with the rear seat upholstery included ready to install. The column shift has been upgraded to a floor shifter and console. A new white top is currently in process and will be installed within a few days. The hydraulic hoses were just replaced, and the top works well.
Now onto the spare parts! This car comes with tons of spare, and new parts to make a perfect restoration. Just some of the spare parts include:
-Mint grilles and trim restored, and ready to install
-Excellent rocker moldings/gills
-Extra Formula S hood + extra inserts
-Many extra dashes/gauges and radios
-Many extra A/C evaporator boxes
-New seat covers (fronts being installed)
-New carpet set (being installed)
-New door panels (standard and deluxe)
-New convertible top and well liner (being installed)
-Park lamp assemblies
-Several extra taillights and lenses
-2 sets of extra headrests
-Carter AVS carburetors
-New headers (no name)
-Trunk upper and lower trim, perfectly restored! Very hard to find, and $$$$
-MORE trunk upper and lower trim, unrestored but with no dents/dings and easily polished and restored
-Boxes of various extra trim and weather-strip
-Numerous extra engine parts... 340 heads, intakes, exhaust manifolds, pulleys, AC Compressors
Too much to list!
$18,500 or best reasonable offer. Lower the offer goes, less necessary parts that go with car.
1968 Plymouth Barracuda
Please follow link for all pictures.
Too much to list!
