quartermilepass
1968 plymouth barracuda fastback
Car has a mopar big block 400 in it
Motor has bigger valves bigger cam double rolling timing chain.
727 transmission with a 3,000 Stahl converter
Rear is a 8 3/4 with 3.91 gears
Not the correct front seat but comes with the two correct bucket seats with new foam to go with.
There is a bunch of extra parts that come with the car.
Car runs drives and stops.
I originally purchased the car non running and driving, so can answer most questions you have about the car.
Front and rear frames are good. Floors are very solid with no holes , they were partially replaced with correct panels but if you are looking for a show car you will need to do a full floor if you care enough.
Rockers and lower quarters are starting to show rust. Rest of the interior is in very decent shape. Drive the car and fix what you want when you want.
Price is 19k located in south jersey.
Will Consider any reasonable trades.
Mopars race trailers , even if we talked before send it over.
