1968 BARRACUDA FASTBACK FOR SALE
LOCATED IN RYDAL, GA
ASKING PRICE 45,000.00
Prowler flame orange pearlcoat
ENTIRE CAR BLASTED (on whirly -jig)- NO RUST
BASF PAINT
GHOST FLAMES FRONT FENDERS
RECHROMED BUMPERS
RECHROMED DOOR HANDLES
STAINLESS STEEL DOOR LATCH
AIR OPERATED HOOD
FIBERGLASS 6 PACK HOOD
STAINLEES TILT COLUMN
FLAME STEERING WHEEL
DRIVER & PASS ELECTRIC WINDOWS
5 POINT PENTA FENDER BOLTS
CHROMED HOOD HINGES
NEW INTERIOR
NEW RUBBER
NEW CARPET
NEW HEADLINER
NEW GAUGES
NEW ALPINE CD
NEW FRONT GLASS
STAINLESS STRIKERS
NEW AC/ HEATER-STAINLESS LINES
NEW FUSEBLOCK AND WIRING
440 EMBLEMS ON SIDE OF CAR
DUEL 12 VOLT BATTERIES IN TRUNK
ALUMINUM RADIATOR
PENTA STYLE OVERFLOW TANK
SPECIAL MADE ALUMINUM ELECT FAN
TIRES & WHEELS
FRONT- FLAME WHEELS
15 X 6
215-15 X 60 BF GOODRICH
REAR- FLAME WHEELS
15 X 8
295-15 X 50 BF GOODRICH
ENGINE:
Boiled & de-greased block
Magnafluxed block
Bored block - .030
Honed Cylinders with honing plate
R&R Cam Bearings
R&R Freeze Plugs
Regrind Crank 10-10 & Polish
Recondition FORGED Rods - new rod bolts
R&R Rods on Pistons - Forged Pistons 10.1 Compression
Balanced Complete Assembly
DOUBLE TIMING CHAIN
CRANE HYD CAM #643801
HIGH VOLUME OIL PUMP
BARRY GRANT CARBS- 650 DOUBLE PUMP- 2 EACH
SPECIAL MADE AIR CLEANER
CUSTOM MADE INTAKE
VERTEX DISTRIBUTOR / 10MM WIRES
STAINLESS DIST HOLD DOWN
STAINLESS VALLEY PAN HOLD DOWN
CUSTOM MADE VALVE COVERS
CUSTOM MADE FUEL LOG- ALL STAINLESS
ALUMIMUM WATER PUMP & PULLEYS
CUSTOM MADE ALUMINUM BRACKET FOR A/C & ALT (CHROME ALT)
STAINLESS 2 1/2 MUFFLERS
HEADERS -TTI
TRANSMISSION:
727 RB Transmission
Heavy Duty 4 Clutch Pack
High Powered Drum
Semi-Metallic Friction Bands
HP intermediate low band
5-0 Ratio
Reinforced band struts
4 pinion input planetary gear
Hardened Input Shaft
Modified Valve Body and Governor
Improved Lube Oil Circuits
3000 STALL CONVERTER
STAINLESS TRANSMISSION MOUNT
ALUMINUM DRIVESHAFT
UNDER CARRIAGE:
ALL NEW COMPONENT FOR FRONT END
MAJOR PIECES- POWDER COATED BLACK
NEW QUICK RATIO STEERING BOX
COIL OVER SUSPENTION
STAINLESS STRUT RODS
SUB FRAME CONNECTORS
NEW DANA 60 Strange 35 Spline Axles with 5 X 41/2 bolt circle,
new Spicer 3.54 gear ratio, Spicer Traclock Posi, new 1350 series yoke,
all new Timken Bearings and Seals.
LARGER CAPACITY REAR END COVER
LADDER BAR REAR
All 4 stainless brakes--(stainless brake corp)
ALL NEW STAINLESS BRAKE LINES
STAINLESS FUEL TANK
NEW ELECTRIC FUEL PUMP & FILTER
STAINLESS FUEL LINES
BASF PAINT
RECHROMED BUMPERS
AIR OPERATED HOOD
CHROMED HOOD HINGES
NEW INTERIOR
NEW RUBBER
NEW CARPET
NEW HEADLINER
NEW GAUGES
NEW ALPINE CD
NEW FRONT GLASS
STAINLESS STRIKERS
ALUMINUM RADIATOR
TIRES & WHEELS
FRONT- FLAME WHEELS
15 X 6
REAR- FLAME WHEELS
15 X 8
ENGINE:
Magnafluxed block
Bored block - .030
R&R Cam Bearings
R&R Freeze Plugs
DOUBLE TIMING CHAIN
CUSTOM MADE INTAKE
HEADERS -TTI
TRANSMISSION:
727 RB Transmission
High Powered Drum
5-0 Ratio
ALUMINUM DRIVESHAFT
UNDER CARRIAGE:
LADDER BAR REAR
STAINLESS FUEL TANK
