[SOLD] 1968 Barracuda Formula S tribute Pro Touring, MD
flyusmc
Member
Pasadena, MD
Rating - 0%
0   0   0
I bought my Barracuda in 2004 and every deployment have fixed it up to where I want it. I just got back from my 5th Deployment and I hope I'm done!
I have poured my heart and soul into this and have a huge stack of receipts of over well over $68K in JUST PARTS!!!! It is set up for Road Race, Street cruise, autocross, drag strip, cross-country drives, Pro-Street, over 1.0 G on the skid pad, EVERYTHING! I will do my best to describe everything but please know I've done so much I'm sure I'm forgetting tons!
Basic Specs:
Motor:
Built, stroked (.30 over), strengthened, and lightened 340 small block (~416 CI) All the goodies. In its current tune it should be putting down ~450 hp and 510 TQ. I had one horrible out of tune run at it laid down 353hp and 460 tq at the wheels. I have since tuned it all out, and it runs great. Does not smoke, drip, or use anything. It has around 9.4:1 CR and you can use 87-89 octane. Even consider putting a turbo with this low compression. I've gotten over 20 MPG on the highway. Eagle 4.0 stroker crank, forged dish pistons, Mopar purple cam 7000 RPM, Edlebrock 340 aluminum heads, titanium valve train, solid lifters, Edlebrock RPM Air gap, tuned Holley 750 CFM double pumper, duel fuel inlets, fuel regulator, electric fuel pump, MSD billet distributor, MSD 6A ignition, It runs GREAT and cool in the dead of summer.
Transmission:&
Tremec TKO-600 5 speed manual, driveshaft safety loop.
Exhaust:
TTI and X-pipes etc.
Suspension:
Bill Reily installed Alter-K-Tion Front Suspension with Power steering, Street Linx 4-Link Rears QA1 Shocks all round, and of course Flaming river everything. subframe connectors, and a mini-tub
Wheels:
Vintiques 17" Mopar Ralley style Special custom size only available from the factory.
Tires:
Nitto 505 245x45x17 front and 285x40x17 rears
Lots more to include painless wiring harness, grant wheel, high flow water pump, light weight starter, uninstalled new dash, solid sate tachometer, New belts, New fuel tank, NOS space saver good year spare, build sheet, not installed AM radio, car cover (always garaged anyway), not installed rare 4-speed consul, not installed extra gauges, etc . ;This is a once in a lifetime chance to buy a %98.9 mechanically finished and 90% cosmetically fished dream machine for a fraction of the costThanks and of course you are welcome to e-mail and if you leave your number I will call back ASAP. To make this a $200K show car here is what I would do: I'm sure I am forgetting something just ask specifics. Slow electrical drain - I think this is coming from the ignition, but I just disconnect the battery every time so it does not bother me. Re-do the interior including putting in carpet. It is driver quality now but I have quite a few parts needed to update&. Repaint the exterior, again this is a drivers quality car and the paint looks good but there are some small bubbles and scratches, rough repaint section below the gas fill up flip switch, where it leaked down. a small dent in the hood from the too big air cleaner stud new handles and exterior mirrors. (Again they are all driver quality but show age).Tail trim needs dents taken out. A couple of smaller dents in the front light surrounds. Heater is stuck on low, it shorted out this way once and I have a new switch I have not yet installed, I have shut the heater doors, so it does not blow hot. Install the Am radio or a radio of your choice. Only the ammeter, lights, turn signals, and tachometer work current. All gauges did work but have slowly deteriorated. I have uninstalled gauges I to use. I would probably buy a new board. I have ton's of extra parts and new show quality parts to go with this including a brand new dash.
$26,500 Or Best Offer
Near Baltimore MD. (21122)
Contact Andy
Thanks for the nice comments! Like I said in my add, I've poured my heart and soul into this car. :D It is such a blast to drive and easy too. When I had my car dyno'ed the operator had just finished 300+ cars (dyno day) and he says to me jaw dropped; " I just dyno'ed 300 + cars from modern mustangs to classic Chevy's... THIS car is the easies car to drive I've ever driven " :D .
That was my whole point in building this. Easy to drive but capible beyond compare.
FLYUSMC
First Thank you for your Service!! Nice Ride ! best of luck on your sale
