1968 chrysler 300 front wheel cyl (drums)
dusterdood
The Duster Guy
Rochester, NY
How do I get the front wheel cyl off of my 300? It's got drums, and I've not had a drum front brake car before. I can get the rubber hose off, and the rear bolt, but on the front bolt there's not enough room to get a wrench on it. Anyone here have C body experience? I really can't see a service item like a wheel cyl needing the backing plate removed to get it off.
Thanks, mike
Mike,Being a A-body/C body man,the easiest way is to remove the backing plate from the spindle and then unbolt the WC,if you do not,you will just get pissed off and kick the neighbors cat,if you need help,450 424 0445,Mrmopartech
Neighbors' pets will be safe, just couldn't believe that was the way they intended it to come off. Thanks for the help.
Mike
