1968 Dart GTS
vwpickup
New Member
Nova Scotia, Canada
I bought this car last October, I didn't get to drive it much before it got put away for the winter.
Once I put it away, I started with the idea I would freshen up the engine with a 340 I had started building20 years earlier for another mopar project. The bottom end was put together and pistons installed then it got oiled down and wrapped in a garbage bag for approximately 20 years.
My plans are to set the original engine aside and eventually rebuild it and put it back in the car. After months of ordering parts and putting the engine together, I pulled the old tired engine out, cleaned up the engine bay a little and gave it a fresh coat of urethane paint. I installed a new updated wiring harness, new steering box power steering lines and pump. I also made up some new stainless steel brake lines and transmission lines.
I installed the fresh engine and fired it up, made a few adjustments and I am very happy with the way it sounds and runs. I also installed a new stainless exhaust and new stainless tips.
After completing the engine I started on replacing a lot of the chrome. Mirrors, door handles, grille and headlight bezels, hood inserts, side markers, fender turn signals, new tail lights and trim. Then I started on the trunk finish panel. I started by stripping the paint off of it, repairing the dings that were in it, buffing all of parts that should be buffed, taped it off, primed it and painted it. I am very happy with the way it turned out.
At this point it is almost ready to start driving as I continue to improve on what I can.
Thanks for all the comments!
Anyone have experience with AMD bumpers? The bumpers on this car have been re-chromed and
are not in the best of shape, front one has taken a couple of bumps and pushed in on the ends.
Or are there any other sources for bumpers?
Couple of more pics.
Have a set of AMD front and rear bumpers for my 68 Dart. They are a decent value. Are they as perfect as custom chrome replacing? No, but they don't cost 1600-2000 as replated originals do now days.
