[SOLD] 1968 Dodge Dart 2 Door Sedan 360 / 727 / 8.75
tcherney392
Active Member
New Jersey
Rating - 0%
0   0   0
Asking 15k, I'm looking for offers.
L - Dodge Dart
L - Low
21 - 2 Door Sedan
B - 225 1 BBL 6 Cylinder
8- 1968
B - Hamtramck, Michigan
Clear NJ Title In hand
Good: Clean Driver with loads of new brand name parts. Runs and Drives with ease.
Bad: Small section of the rear window trim doesn't sit flush, (the guy who installed it should be coming back after the holiday to fix it)
Engine / Transmission
Mild LA 360 - Cam & Double Roller Timing Chain by Comp Cams
Recently rebuilt J heads, decked & smoothed ports
Mr. Gasket's Ultra Seal engine kit
Factory HiPo LD340 aluminum intake
Holley 670 - (electric choke/ vacuum secondary)
Powermaster (175091) 1 Wire Alternator
Proform HEI Distributor
8mm Moroso Ignition Wires
Polished Fabricated Valve Covers
New Water Pump / Fuel Pump / Oil Pump / Belts
2 12" Electric Fans w/ Fabricated Shroud
Hayden Fan Controller
New Hoses
727 w/ shift kit
B&M Finned Aluminum Pan
Rear Differential
8 3/4 - open 3.23s in a 489 case
Yukon axles
Bosch AGM Sealed battery
Exhaust
Dougs headers w/ DEI silver silicone coating & DEI titanium exhaust wrap
Pypes full stainless steel exhaust
Dynomax super turbo ss mufflers
2008-2014 Dodge Challenger exhaust tips
Brakes
Front : New Drilled/Slotted Rotors / Pads / Calipers / Lines / Hardware
Rear : Drums New Shoes / Hardware / Wheel Cylinders
Pirate Jack Power Brake System - Master cylinder & Booster
New Steel lines throughout car
Body
Chrysler PS2 Silver Metallic
Paint to match Bumpers w/bolt delete
Recessed Exhaust Tips
Matte black grill
Matte black tail light bezels
Paint match door handles
Paint match bumpers w/ bumper bolt delete
New Washer Bottle / Pump / Lines
New Front Windshield & Front / Rear Gaskets
New Door Gaskets
New Trunk Gasket
New Hood Gaskets Front / Rear
New Windlace throughout interior
New Cat whiskers for all windows inside and out
Interior
Drag Pack Challenger Front Seats
Modern click style 3 point seat belts
Modern rear seat belts
Refinished dash
New glove box liner
New Carpet
Bosch Gauges
Tach
Water Temp
Oil Pressure
Power Steering / Suspension
New - Gearbox / Pressure Line / Return Line
New Inner/Outer Tie Rods
New Upper/Lower control arms w/ large ball joint conversion from later model dart
New Monroe Shocks Front / Rear
Front / Rear Sway bars
Energy Suspension Red Poly Bushings
17" wheels up front 18" Wheels in the rear w/ Goodyear Eagle F1s
L - Dodge Dart
L - Low
21 - 2 Door Sedan
8- 1968
New Hoses
727 w/ shift kit
Rear Differential
Yukon axles
Exhaust
Brakes
Body
Matte black grill
New Door Gaskets
New Trunk Gasket
Interior
Refinished dash
New glove box liner
New Carpet
Bosch Gauges
Tach
Water Temp
Oil Pressure
17" wheels up front 18" Wheels in the rear w/ Goodyear Eagle F1sView attachment 1715002811 View attachment 1715002812
Like to see more pictures
