Here is my A-body. A 1968 Dart 270 with a 225 /6, 904 on the column.
Nothing other than a great running car at the moment.
I have big plans for the engine so I have been working on the suspension and brakes first (I usually do it the other way like everyone else does but I like to drive it as is till I get all the engine parts assembled).
The rough draft of the plan is to have a Fuel Injected, Turbo Charged 225, fueled with Ethanol. The reason is the E85 has a temenduos cooling effect and around 105 octaine which I just think makes since for a turbo engine. I am a bodyman by trade, i've never programmed a fuel injection system before but I have re-built and swapped engines before. I have basic tuning abilities and a good network of friends that are willing to help. (They might just be watching me to see my goals go up in smoke, but isn't that what freinds are for?)
The front suspension is all rebuilt and will be adding disc brakes to the front when the new drivetrain gets installed. I still need to find a rear-end for it so the bolt pattern will be the same as the front. I might try a 8 1/4" out of a '70's A-body for a while till I find a reasonalbly priced 8 3/4" (or do I dare say 9" here?).
I will replace all the wiring with a painless kit (or the equivilent) so I don't burn the thing to the ground.
And there are a million other "dreams" but so far that is the plan. Here are some of the pics I took when I brought the car home in May '06. It's my first MOPAR but thanks to my customers, not the first one I have tore down to nothing and re-built!
It is rock solid and needs paint as you can see. The problem is after 8 to 10 hours of painting other peoples cars I don't even want to dig into the body. I like the "Rat Machine" idea for now. We used to call them sleepers but when I mentioned sleeper to my kids they just invisioned the back of a big-rig!
Thanks for having me!!!
Chris
Chris
