JetCity68Dart270
Active Member
1968 Dodge Dart 270, Nice business coupe that originally had a 273 v-8- not a six cylinder with 88,000 miles*. I think it was an L.A. built car that was sold in Seattle. I am a huge fan of Larry Shepard so I was going for a Ramcharger's vibe. Super Stock Dodge. Now there is a 1976 360 LA small block w/ Lunati Voodoo cam 256/262 (http://www.lunatipower.com/Product.aspx?id=2341&gid=297), Mopar Performance valve springs, double roller chain built by Jay's in Everett Spring of 2012, it has around 2500 miles on the rebuild, broke in and refilled with Rotella. Mopar Performance Electronic ignition, Holley Steet Avenger all aluminum four barrel, vacuum secondary, dual feed 570 CFM (http://www.holley.com/0-83570.asp), Weind single plane intake with carb studs, K&N air filter, Schumacher motor mounts; 904 automatic transmission, B&M shift kit Hurst Promatic 2 tall ratchet shifter to clear the Swinger high back bench seat; Sure grip 71/4 with 2.93 gears, KYB gas shocks, Kuhmo 13" tires with small bolt pattern rims, correct hubcaps. Flowmaster mufflers with crossover pipe and chrome tips. Tach and oil pressure gauge. Recent paint over rough body. Squeaks, rattles, leaks- (price is negotiable- I would like to keep the air cleaner, carb and ignition ) fun to drive, project race car, super stock, 1968 hemi dart, rat rod, private investigator stake out vehicle, time travel machine, movie or rock video prop
*true to the best of my knowledge
