Ckeely
1968 gtx 440 four speed DANA 60 3.54. This a original CAR . I bought this from a friend of a member with the original numbers matching for 440 in the car . After I bought it I decided to completely go through the drivetrain to freshen everything up. It has been rebuilt Complete . Are used a 70 block instead of the original because it was 60 over and I did not want to take a chance on hurting it it will come with the car as well as all the other original engine components that I did not use . It has a scat Rod , Ross piston balanced short block with a deep sump hemi pan . The original 68 heads were completely rebuilt with Mopar performance roller rockers no expense was spared on this motor . Are used a Edelbrock rpm intake with a comp cams split pattern version of the 509 cam. This is a very drivable powerful combination for the street very impressive . The trans that was in the car was not correct so I bought a completely rebuilt 18 spline year correct four-speed. Had a brand new driveshaft made and the Dana 60 was gone through even though it was in good shape. I see no signs on the car of body panel or subfloor replacement it appears that it has been an original car all it’s life . It has been converted to a doctor DIff disk brake set up on the front end, with a modern master cylinder for driving. Original QQ1 blue with white interior. This is a very nice solid car you can drive anywhere as well as a cold case aluminum radiator the original goes with the car . You’re welcome to call with questions and more pictures. Chris 317-517-0817. The price is 45K . I have quite a bit more in that now I did not expect to sell but a 68 RT charger fell into my grasp. This is a nice car that can be enjoyed and driven anywhere not perfect but very nice . Also this is a manual steering, manual break, manual transmission radio delete car originally. I put gauges in the radio delete plate that are very tasteful all lights and gauges work as they should
