[WANTED] 1968 NON AC Heater Box/ Parts
I have a box from a 69 I think the doors broken off as the hinge was tight and tried to open it
I have a box from a 1970 Dart - only difference is the heater core tubes. 1969 & older have 5/8”. 1970 & newer have 5/8 & 1/2”. Numbers on box would be different but can be changed for the purist. In CT
I had to repair mine also, lower hinge broke, freed-up the hinge and JB welded it for now. Has the heater box you have ever been apart? What are you asking for the box? Thanks Mike
I'm not a purist at all. Mine was taken apart and the steel plate that the motor mounts on was removed at one time and the lip that it was riveted to is badly damaged. What are you asking for the housing? Thanks, Mike
As far as I know it’s never been apart car came off the road in the mid 80s
