1968 Plymouth Barracuda Neutral Safety Switch
NSS is on the transmission, wire goes to starter relay. 65'
68? / earlier has a single post NSS on the transmission. This grounds the coil of the starter relay so that when you twist the key, the relay coil will activate.
69?/ later has a 3 pin NSS the center pin is NSS and the outer pins are the reverse lamps
On your car if it has the single pin switch, the switch on the shifter is for your reverse lamps
1968 barracuda with 727 TF
How do I bypass the neutral safety switch?
It has one wire coming up and plugs into the starter relay
Can’t figure out why the motor is not turning over
