[SOLD] 1968 Valiant road racer
lilcuda
My priorities have changed, so I am selling my 1968 Valiant road racer (originally owned and built by Tim Werner). It is an incredible car that will go 150 mph if you dare. It is the most exciting car I have ever driven. Unfortunately, it is time for me to pass it on to the next owner.
Car was featured in Mopar Muscle magazine a few years back. Here are links to the articles.
1968 Plymouth Valiant Project 7.0 Small Block Engine Build - Mopar Muscle Magazine
1968 Plymouth Valiant 427 Engine Swap - Mopar Muscle Magazine
1968 Plymouth Valiant - Track Day Prep - Mopar Muscle Magazine
Chassis: Mostly original paint (has chips & dings), all steel body, torque boxes, frame connectors partially welded to floor. 6 pt cage, firewall to frame rail bars underhood, XV front chassis (radiator) brace
Engine, 7.0 liter Small Block dynoed at 519 hp @ 5800, 506 lb/ft @ 4100: 340 resto block, AN connections at oil filter. HV pump, remote filter, 3 QT Accusump mounted behind passenger seat. K1 4.125” stroke crank, K1 rods, JE pistons 10.5 compression. Edelbrock Aluminum heads - Stage 3 ported by Hughes Engines with 2.08 intake valves. Comp roller cam 236/236 at .050 with .545”/.537” lift, Comp solid roller lifters, Comp 1.5 ratio rockers, Milodon road race oil pan, MSD E-Curve distributor. Edelbrock Victor 340 intake ported by Shady Dell, BLP 650 CFM carb. TTI ceramic coated headers, TTI 2.5” X-pipe exhaust with Magnaflow mufflers.
Trans: A-833 with 2.66 first gear in Passon Performance aluminum case. Hurst shifter solid mount. Steel flywheel - McLeod clutch
Rear: 66-7 B-Body housing with 2.94 center section, Dr. Diff clutch type differential. Aluminum driveshaft.
Brakes: Front - Baer 6 piston, 13” two piece rotors Rear—Mustang Cobra rear disc kit from Dr. Diff. Mopar aluminum master cylinder 15/16” piston dia. Wilwood rear pressure valve - adjustable from drivers seat. Carbotech pads all around.
Suspension: Front - 1.20 T-bars, 72 K frame seam welded, reinforced with FFI kit, notched for oil pan clearance, boxed for NASCAR-style Speedway Engineering sway bar, FMJ spindles, FFI upper A-arms, Lower arms boxed with AR Eng plates and setup for heim style endlink. Poly lower control arm pivots w/AR Eng retaining plates, FFI C-body tubular tie rods, FFI Stage 3 steering box with PS cooler mounted behind grille. Poly strut rod bushings. Bilstein shocks. Rear- AR Eng front hangers, F-body rear shackles, 340 rear springs with poly on both ends. Adjustable frame mounted rear sway bar .875”. Bilstein shocks.
Misc: trunk mounted battery, light weight Toyota 60A alternator, custom dash insert with Autometer gauges, Extra-large warning lights for oil press, H2O and volts. Aluminum radiator with SPAL sucker fan – Manual switch and thermostatically controlled. Corbeau seats with 4 pt harnesses. Heater/defrost removed, factory glass all intact, wipers & turn signals function as factory.
Wheels/tires: STREET 17x8 OE Bullitt wheels with 245/45-17 Goodyears and TRACK 17x9 Konig Villains with 275-40-17 Kumho V710’s (I was told they are pretty old and should be replaced) - Car WILL accept 275/40-17’s on all four corners with no clearance issues
Also included are fiberglass bumpers and a spare rear sway bar.
I also have a spare case, NOS 3.23 gears, a brand new TruTrac diff, new yoke & ring gear bolts that I will include for the right price.
I would like to see this car get out on the track where it belongs.
More pictures available on request.
Asking $20,000
Located in the South Bay area of CA.
Please contact me via PM if interested.
I also wanted to add that it is street legal and registered in CA. Here are a couple more photos.
Asking $20,000
