1969 (340) 416 stroker shortblock
$2,200
Freeport, PA (16229)
416 stroker shortblock. (11-20-19) 340 block bored and honed needing only cleaned to assemble (.030 over 4.070 bore) 4 inch Scat cast 4 inch stock crank, 12-1 Diamond Pistons, Scat I beem rods, Cam Motion solid cam S2632-08 cam and lifters, Canton oil pan 915-9000 and oil pick-up, new rings, Billit Rollmaster timing chain, BHJ damper, cam bearings installed, nice stock timing cover, B&M flexplate, and entire assembly is externally balanced. At the time I will not ship but local delivery may be possible or local delivery. 2200.00. located in Freeport Pa. 16229. 35 miles NE of Pittsburgh, PA. Please message or post questions.
$2,200
