[SOLD] 1969 340 block and part
css426truck
wi
The crank is a nos std 3.510 mopar 8 bolt. The piston are 360 mopar kb 107 .070 the 360 is a 4.00 bore an a 340 4.040 bore so this make the piston .030 for a 340. The rods are new eagle 340/360 with bushing. The block is a 1969 340 std. the engine is bal. and for a added $450 can be bore an hone with a plate an mill the block. $1800.00 + the $450.00 for the bore. All so a set of 340 x heads foe $400.00 good core to rebuild
Are you sure about that crank stroke? That's kinda strange. It will give a -.047" deck clearance and figuring 68cc on the heads 9.2 compression. Nice parts and it'll certainly work......most people shoot for closer to zero deck height. Was there a reason for this particular combination?
I ask because I have a friend who might have interest.
I check my engine math at doverusa.com an a bore of 4.070 5cc for piston head gasket of .018 steel oem deck of .025 and a stroke of 3.510 the engine is 10.08 to 1
That aint right. Go to the United Engine site and plug in the following in the deck clearance calculator.
deck height- 9.6
rod length -6.123
compression height- 1.675
stroke- 3.51
You will come up with .047 in the hole. Unless that block has been decked, that's what you will have. That's why I asked.
Now, I ran the compression calculator with the generic .038" head gasket, so your thin gasket would add some there, but somehow, you got the deck height wrong.......unless the block has been decked and you know that specific number.
Went back and ran the compression figures with your .018 head gasket and got 9.6. I used 68cc's for the heads.....another unknown, but good guess. And for the gasket bore I used 4.1 which is pretty popular.
Just curious, where are you getting .018" thick head gaskets? I think a lot of guys would want those.
OK think out side the box! Mill the block .020 a good engine build can help you with this and look for nos steel head gasket .016-.018 and check the math one more time Check out ebay #3216345883459. This maybe why I not selling parts out side my shop.
