1969 340 cleaned and disassembled
LXguy
Champaign IL
Hey All:
Going to turn loose of this 340 instead of building it. Everything has been hot-tanked and cleaned up well. It was in the middle of a ring and bearing rebuild when I got it.
Crank is in the block with new bearings (Don't know if it was turned or not, kinda doubt it), block has new cam bearings and freeze plugs. Double roller timing chain, and I think the stock cam!
Standard bore, cylinder walls look really good. Out of a stick car.
X heads with valves, need rebuilt (have all the original springs, keepers and whatnot). Other than cleaned they are untouched as far as I know.
Factory cast intake, original oil pan (384) and windage tray, timing cover, valve covers, oil filter adapter, etc.
Original rods and pistons with it also.
I also have the dual point distributor and factory air cleaner that I was going to sell separately. Sadly, I do not have the factory carburetor.
Includes complete gasket set, remainder of the bearings, rings, etc.
$1000 obo
Would greatly prefer pickup. Am going to Monster Mopar this year, could haul it there if prepaid.
Thanks FABO!
