moparraceman
NOTE THE BLOCK has 9-10-68 ON IT SO GUESS ITS REALLY A 69 BLOCK ready to be assembled with new parts 1969 std bore 340 motor block new cam bearing installed ,been cleaned and fresh hone ,steel crank std std ,new seal power pistons [speed pro ] new rings,rod and main bearings ,has hp comp timing chain set ,excellent oil pan, pump , and pick up ,windage tray ,front timing cover,water pump,fuel pump ,dist -oil pump drive gear shaft, steel crank balancer , NO HEADS put a set of j or x heads on have a great motor cheap. for the short block $2000. pick up ohio thanks
