Tsully
383 Mopar Shortblock is .60 over with a Lunati 292 Hdy Voodoo Cam, steel crank. I have the 2 sets of 516 heads that go with it. Motor has about 500 miles since rebuilt... I did not rebuild it, was supposedly recent rebuilt when I bought the car. Couldn’t Get the headers to stop leaking at the header bolts tried another set of heads no success, so I am going back to small block with factory manifolds.
Motor ran great with no issues other than leaking water at the exhaust bolts. Oil pressure at 800 rpm idle and at 180 degrees was around 20psi, cruising it would be around 40psi. Has an A body 187 oil pan on it. Pistons are showing to be .30 in the hole.
Asking $450.00 located in Saint George SC...not willing to ship.
