1969 383 shortblock, all race grade machine work, 010/010 forged crank, oem beam polished/mag'd/shot peened rods, ARP wavelock bolts, TRW 2315 forged pistons, Speed Pro ductile/moly rings (.020/.018 end gaps), Clevite 77 bearings, brass core plugs, MP intermediate pump drive shaft, Melling blueprinted std vol oil pump, windage tray, 187 oil pan, Lunati VooDoo 268/276 hyd cam, Jegs 9way 3 bolt double roller timing set, clearances set: +.004 skirt clearance, .006" thrust, rod and main bearings +.002", -.002" deck, block ground/deburred, cyls bored and honed w/BHJ honing plates, VHT Chrysler 'early blue' (turquoise) engine enamel, 440 source damper indexing tape, a great street engine with boss drillings for late '60s A-body engine brackets. If you're looking for a very good short block for your 67-69 DP A-body, this is it, $3000 firm, plus shipping. located in Savannah, Tn. Interested parties pm me here, thanks for viewing...wb
