Chris pugh
I do believe this is to standard bore based on the OEM part number on the original pistons. There is barely a lip in the cylinders. The block has a BH29 vin stamping indicating this is an original A Body barracuda 383 HP block. I am not sure of the value taking into consideration someone with an original 383 barracuda missing the original engine and wanting to be as close to correct as possible or if someone gets really lucky I may have the original block for there car... with only around 700 units produced this stamped block is not very common.
I have the block, main caps, rods and pistons, and intake.
I am located in
Dalton ga 30721
Asking $1800 Or best reasonable offer
I am located in
Dalton ga 30721
