Yes it did, I had both manifolds on a triple black Cuda, sold now. The c-body manifold was modified by Accurate Exhaust with a extension tube welded on, but by changing the ex pipe stock will work. I had mocked up the manifold with engine in car and steering cleared and opening was above starter.
I have the original LH manifold that came on car( he still had it after 50 yrs) but am going to run Tti headers because he said when he put on fender well headers on it,,, it was like adding a hundred horsepowerYes it did, I had both manifolds on a triple black Cuda, sold now. The c-body manifold was modified by Accurate Exhaust with a extension tube welded on, but by changing the ex pipe stock will work. I had mocked up the manifold with engine in car and steering cleared and opening was above starter.
I paid $3500 for the almost NOS manifolds back around 04
Yeah I think my fold down rear seat is made of lead it is crazy heavy. But it is strong adults can climb back there and it don't flex at all. But fold down rear seat was an extra cost option in '69 where as in previous years standard in all fastbacks.Alan
Correct
1969 Rear Glass Weight
* Dart ............................. 19.7 lbs.
* Barracuda 'Notchback' ..... 19.7 lbs.
* Barracuda 'Fastback' ....... 56.0 lbs.
Also, the Barracuda 'Fastback' had a heavier Rear Seat {+27 lbs.},
due to the heavier seat frame and fold-down hinge assembly.
Also, there was additional body metal around the Rear Window
frame of the Fastback {+12 lbs.}.
Easy to sneak in drive insYeah I think my fold down rear seat is made of lead it is crazy heavy. But it is strong adults can climb back there and it don't flex at all. But fold down rear seat was an extra cost option in '69 where as in previous years standard in all fastbacks.
Oh, I’m not saying they won’t fit. But they are not the same.Yes it did, I had both manifolds on a triple black Cuda, sold now. The c-body manifold was modified by Accurate Exhaust with a extension tube welded on, but by changing the ex pipe stock will work. I had mocked up the manifold with engine in car and steering cleared and opening was above starter.
Of course they’re not the same but from top one can’t tell the differenceOh, I’m not saying they won’t fit. But they are not the same.
